Dear All, I bought new Suzuki Mehran VX Euro II 2013 but i am facing an issue in itWhenever i open Fuel Tank Cap for refilling a pressure of air comes out from fuel tank. I don't know may be its due to Evaporation of fuel. but i think i could be dangerous. i want to know the cause of it please guide me about it Experts please help...
Regards,Adil
I also face this problem abi mayree Mehran tu bass 39KM chali han bahi
My mehran also does the same thing...dont know whether it's normal or not...
Sent from my GT-P3113 using PW Forums mobile app
Its normal.
Dear Mahmood, Suppose karian k ye pressure Fuel Evaporation ki waja se banta he agr hum fuel tank ko fuel se full karwa kar cap ko kuch time period tak open nahi krte like 10 to 15 days to pressure kitna ziada dangerous hosakta he maine to dar k mare abi tak tank full b nahi karwaya just Rs 1000/- ka petrol dalwata hon or jub end hone lagta he phr dalwa leta hon. or car just 10 km b chale to pressure ban jata he or main car ko rok kar pressure release karta hon or phr dobra drive karta hon is car ne to tension main dal diya he.
Dear Zia, Can you please explain how its normal ?Thanks in advance.
ok Thanks to all of you
I faced the same problem in my mehran, it also used to build pressure and mechanic used to say that its normal, but its not normal as fuel tanks are not pressurised, there is breather pipe attached to the fuel tank, if you people look under your car you will find a smaller diameter pipe beside the main fuel tank pipe from which fuel is filled, the cause of that problem was that in most of the mehrans the breather pipe is bent which blocks the air and then when fuel is filled it is thrown back as tank cant breath with bent breather pipe, so i just shortened the breather pipe and made it straight, after this never face such problem in my mehran.
Dear, can you please send pics of short Pipe?
Thanks in advance.
come on yrrrrrrr,,, its common,,,how??? do a simple test,, go to any petrol pump and stay there for 5 mins nd observe every car,,, u will be satisfied
Just adjust the rubber below the tank cap....... This pressure can also give u false fuel level.....
That the picture i got, the smaller rubber pipe was bent previously, so when i made this pipe straight the problem was solved in my car
never fill fuel upto the end of pipe which most petrol stations attendents have habit of doing. Always fill till the fuel nozzle automatically stops refilling.
if your issue is not sorted out Consult Suzuki Authorized Workshop. Your Mehran is Under warranty they will guide you better btw this thing is normal but if Pressure is Building too Much resolve it like one brother said about Breather pipe .
It is a technical problem so some technical person may answer well like XULFIQAR bhai.
Its normal my gli 2010 model when i open tank air realeaze with presure like in my 2012 euro tooi will say u its normal
For that there is a Purge Solenoid Valve that releases the pressure back into the intake manifold every times when the Engine cranks,
I dont know about PKDM vehicles but i have seen "Purge Solenoid Valve" in almost all JDM Vehicles
I am Planning to buy new Mehran Euro II..if you are using it for few months?..kindly let me know of your experience?..How you find it?..there are rumors..Its Fuel consumption go increase after three four months?..looking for your brotherly advice..btw till now i choosed to go for Mehran coz it looks most economical in every perspectives and have a very good resale value..
Share your experience with me?..
slam to all friendz .. ap sab ko mien bata do k mehran ka fuel pressure banne ki waja fuel cap ha agar bht high pressure ban raha ha to ap fuel cap ka rubber utar kar ulta kar k lagaiey ge to pressure banna khatam ho jaye ga ..
