Hello!
I have a Suzuki Swift Automatic 2016 model, I’m having issues with its gear, whenever I’m stuck in traffic or I’m reversing i feel a sense of vibration and it increases. Mene tuning vagera sab kuch karali hai, scanner lagwa kar gear check kia tha tou rpm 600 tak jaraha tha. Koi bata sakta hai k best transmission mechanic KARACHI mein kahan milega?
gear ka issue nahi hoga ye, rpm low ho raha hai,
throttle positioning sensor check karwaya tha ? spark plugs, engine mounts, ye sab check kiye hain mechanic ne ?
use search glass on top right search for Iqbal Shahid he is former employee of Pak Suzuki. He is running his own workshop.
Jee sir, proper throttle body khol kar safayi karwayi, sensor bhi saaf kara, sab karalia lekin ye masla hal nae hora. Scanner laga kar rpm check kia tou Stable honay k bajae girraha hai.
If u have cleaned the idle air valve properly this could be a Could be a vacuum leak.
