So after 2 tanks car is still getting worse day by day now. I am at 300km no matter how I drive it. Last weekend I had my car washed and noticed that the clutch is getting hard and after 10 mins of driving I heard something broke while I pressed the clutch and then car went into netural.
The Slave clutch has a plastic bit that is connected on top of the gear box which broke but then after some adjustment it started working but the car wouldn't go in gear. It showed that car is in 1st gear but if you let off the clutch nothing happened. That mechanic said clutch plate and pressure plate is done and I should get them fixed. But again same question if it was clutch plate then how come it just went like that, as it suppose to show signs like missing and all that.
So I took it to one of my mechanics and he made some adjustments in the clutch and then it would start going in gear. long story short I had to get the slave cylinder changed and that fixed it.
I am still try to figure out if issues is my clutch plates. 2 of the mechanics I spoke with say that your clutch plates are perfect and there is nothing wrong with it. It was just an issue with slave cylinder due to the power wash I had it caused it to snap.
Any suggestions from experts would be great. I have tried pushing my car in every way to find a small lag or glitch to see if its clutch plates but nothing shows that is. If anyone knows of any tricks or good mechanics in ISB then please do let me know.
Thanks
