Suzuki swift dlx ABS light comes ON and goes off , mechanic checked every thing electrical , braking , connection every thing seems fine. But still dont seem to understand whats wrong. Would appreciate any advice.
Brake pads 6 months pahle change kerwaye thay,. And 1 month back brake service kerwaye.
Masla jab brake service kerwaye us k thore din baad.
It can be ABS sensor
check wiring and pressure inside the braking systemGii bhai. Japanese dinkies work's well until they got in hands of our mechanics.
sorry i think it's japanese alto mixing ho gae sorry.
Mixed with another thread Galti insan sa hi hoti hai still suggestion will be same.
Check brake fluid level bro.
Have you changed any wheel bearing? If not than go to the stealership, and it could be a faulty abs brake sensor.
Its just due to brake fluid level...top it up and your issue will go away
Brake fluid is up to the level
Your brakes have not been properly serviced, get them serviced properly from someone who knows what he is doing and the problem goes away
Thats what I am thinking too. Have you experience this kind of problem before?
I know someone who did, they got their brake serviced from a more experienced mechanic and problem solved
Well in my case, I actually had to change the front left ABS sensor, problem is solved now. Thanks for all your replies.
