Hi Pakwheelers,
Hope you all are doing good.
I've a Suzuki Swift DLX 1.3 2010 (Manual). A couple of days back, I got its Engine Compression check which came as 110, 120, 120, and 110 respectively. The Car has reduced 20w-50 up to 500ml in 3000kms. (Odo: 213000+)
I'm getting suggestions for Engine Swap and Engine Overhaul. The engine overhaul would cost around 40-50k as per market research and a full engine swap would cost less than that perhaps.
There's no knocking or any kind of weird sound from the engine, so I assume the change of piston rings would be sufficient to improve the compression and oil-reducing problem. The current oil I've been using is Mitasu synthetic 20w-50.
Could you please take some time to provide your valuable feedback? Thanks a lot.
PS: I'm willing to spend the money on a full engine overhaul as well but only if it is worth it. I'm a bit suspicious of kabli engines as we're not certain what the internal condition of the engine is. The kabli engine might also require work in sometime & there's also problem of ecu & sensors compatibility.
