Will do, thanks for the tips and also why not to use hard breaking?
Engine, transmission, braking system will be in initial wear and tear condition. So better to use it smoothly. Experts suggest this
Noted!! also what to check in the Engine Bay?
Is all caps are present (specially AC filling gas cap on front ). Coolant will be near Max line. They will not fill it to Max line.
Rest everything will be ok
Alright Thanks For the help, InShaAllah will look for all of these things
Will be taking my 15â swift for its 75K oil change at Suzuki 3s.
Should i go for the ulimate or that synthetic one ?
Suzuki does not have synthetic.
They have semi synthetic only named as efficient but that is 5W30 which is not for Swift.
So only option left is ultimate (10W40)
Thankyou
NEED SERIOUS ADVICE:Best clutch set(plate,pressure bearing) for swift 2011 modelFCC OR EXCEDY (Aesi hi kuch name ha )?Secondly fitting of clutch plate depends upon mechanic means i have 2 mechanic one is very expensive in terms of labour and second one is cheap . the cheap one had installed clutch plates in my cultus ones and it was f9 but sometime he lacks to find some problem and expensive one is like arrogant but works fine.So does it really depends upon performance of mechanic or every one install it same
I replaced mine with FCC
price?
Doston Abhe swift 2011 me new clutch,bearing,pressure plate dalwai fcc ki mechanic ne daldi mager clutch ka masla horaha tha ke clutch 50% bilkul aram se jarah tha phir baqi 50% ik dum se andar jarah tha aur chorty waqt bhe yehi horaha tha ke car ik dum se pick alerrahi thi jo ke smjh ati ha mager clutch ajeeb hogya tha phir me jab chalrah tha to gear +clutch dono phans gaye aur usi waqt mechanic ko dikhaya to bolrah ha memry pas chordo me dekht hun ye kia problem ha please kooi bataye yeh kia scene ha master cylinder waghera set ha usne dekh lia
Bleed the clutch fluid for air.
6100/-
cylinder ke ik piece leak hogya tha jo kahi bhe nahi milraha tha to new dala ha mager ab clutch bilkul soft hogya ha aur pick bhe zabardast alhamdulliah..mager first gear phir uthey waqt bhuat gandi wali vibrate kerrahi ha mechanic kerh raha ha may be oil waghera laggya ho plate pe kuch days try kero nahi huwa to dekhty ha ..yeh q hoti ha any one knows?
Hey Everyone! Alhamdulilah Got the delivery of my car, just wanted to know 2 things 1. is there a Filter of A/C which is usually present on the underside of the glove compartment, 2. whats the normal tyre pressure ( I know its a stupid one)
Congratulations bro. Yes there is an ac filter in glove box. Recommended tyre pressure is 32 front and 30 rear.
Thank you brother, will check it
Best 3s Suzuki Dealership in Lahore ?
(Workshop)
Per suzuki (check driver door jam) it is:33 psi front30 psi rear with no rear passengers38 psi rear with 3 rear passengers
