Mini motor cavalry ground.
so basically 33 front and 30 rear
also wanted to know that auto of the driver side window only works in one direction( downward direction), is it normal or should i get it checked out
Yes auto mode works only down side.
oh ok thanks
Auto will work in down mode only. For upward you have to keep it pressed.
noted
Hey Everyone! so i dont like the sound of the horn so i m thinking of replacing it with an aftermarket horn what are your recommendations also i am also worried about the fitting aswell should i go for it or not.
swift ki gaskit ki price ka kisi ko idea hay
Around 900 for best quality. don't go for gattay wali gasket.
Get it changed fitting is simple and you can get it done from any good electrician in 200rs plus horn price.
Will warranty be void?
I'm not sure but I guess it would be. You can expect anything from PS.
yeah thats right though
What is the recommended air pressure in tyre for a Lhr-Islamabad route , during these heated days ?
Jazakallah.
2 passengers33 front 30 rear
5 messengers33 front38 rear.
It is mentioned on driver side door.
Finally installed Center arm rest in swift. Ordered it from AliExpress in $43 For gear shift it is ok.
For hand brake I feel bit difficulty. But might use to it after few days.
Overall it is good
Where can i find this Suzuki Alloy Rim - “S” cover!
Free Shipping car-styling 5.4cm 5.8cm 4pc sticker on the car auto sticker wheel covers wheel caps wheel hub cap for Suzuki http://s.aliexpress.com/UNrYBvEZ?fromSns=Copy to Clipboard
Any where in lahore ?
