@ Poster
@ dr.omair
Dear brother i know its very hard to suffer all this, when u have just spent so much money on a new machine and you are so conscious if it has some serious issue? Is it a defected piece? Whats wrong? I know this...
But you are not the only one to face this all... be patient and all ur problems will be removed slowly.
I faced some issues too when i bought my Yamaha junoon back in 2010.
- It used to do missing sometimes and back fire too... later it was found it had a faulty choke cable!
- I had also faced broken throttle cable and clutch cable really early.
- My bike eats up brake shoes early too!
- My head light bulb also gave away early and when it went off.. everything on the Odo, including my indicators went crazy! A faulty head light bulb holder was the culprit! Almost melted down!
- My bike's fuze blew off!
- My bike's flasher(Blinker for the indicators) gave away while fixing something else.. because it was not earth wired!
- My bike has also got little rust here n there because the chrome was already damaged at that point by factory!
- Still to date i dont know why my bike eats up the battery power? It cant power a long proper loud horn! The battery dies and so does the horn if i keep it pressed for long... although i have changed my battery once and am running a 3 AMP one.
These are common issues in todays bikes! Lets face it! Look at the inflation rate! Look at the rupee's devaluation! Bikes prices have not increased equally! And then the most imp. thing is that you and me both opted to chose for a bike that gave "More in less price! " and heres the problem!
When there are such economic conditions, cost of productions is going up, fuel prices, gas, electricity all hiking up... the first thing manufacturers do is:
- Reduce the paint quality! Yamaha and Suzuki both come with a single coat of paint!
- Reduce the chrome quality!
- Reduce the standards of bike's inspection before it leaves factory!
- Reduce the quality of all operating cables.
- Reduce the quality of all parts they manufacture locally... The frame, hubs, axles, brake drums etc.
- Only whats left is the engine that is of better quality because most of its parts are imported and manufacturers cant save cost there.
- Still China has jumped to seize the opportunity and come up with cheaper and pathetic-er quality electronic parts such as CDI units and wiring stuff etc.
Theres no other brand except Honda which offers 2 proper, thick coats of paint! Honda's quality is also decreasing but still not as much as other manufacturer's have decreased. My cousin has a cg125 and he had not got his rear brake shoes changed having 10,000Kms on the odo! m9 ate them up in 3000ish! Its a result of poorer brake drum quality.
After all... how do u think Suzuki managed to give you a 150cc engine! Heavier and bigger sized bike! Self starter! In only 90,000ish Rs? Cg125 comes in that range! In fact Honda insanely thinks they should try selling a 125 @ 115,000 Rs!! So what should be a fair price for a high quality 150? not 90,000 at all!
But still relax! Soon all ur bike's troubles will be solved and it will settle down. Mine has already Shukar Alhamdolillah! Now i dont visit my mechanic as often as i used to... so hope 4 the best and be patient!.
Cheers!
