I am facing an issue in mu suzuki swift 2016 when I turned on Ac there is some noise like tik tik tik like relay voice when i turned off the sound is gone even i just press the aacelater then noise is also gone perfect when drive just make noise when car in stop position what i do now
Same Problem here.
My Swift's AC compressor makes a strange Noise same tik tik tik , but the AC works fine, and when the RPM goes above two, the sound disappears.
any Idea ?
I have changed compressor now this is the only solution i have tried forst to change bearing of compressor but it is not working now install duet compressor it works fine
I think it’s because of the climate control , when u keep the fan on 1 the compressor trips after a short while and makes a tik tik sound again when it’s turned on .
