NEED SERIOUS ADVICE:
Best clutch set(plate,pressure bearing) for swift 2011 model
FCC OR EXCEDY (Aesi hi kuch name ha )?
Secondly fitting of clutch plate depends upon mechanic means i have 2 mechanic one is very expensive in terms of labour and second one is cheap . the cheap one had installed clutch plates in my cultus ones and it was f9 but sometime he lacks to find some problem and expensive one is like arrogant but works fine.So does it really depends upon performance of mechanic or every one install it same?
PIC FOR ATTRACTION
