Dear guys i have recently bought swift auto.I have never kept an automatic car before.would u plz like to tell me when to check and change it gear oil or ATF.
At 70000kms
Also change it with recommend one written on gear oil level stick or on Mannual Book.
If its Aw1. Change the oil with.
Liqui Moly Top Tech 1800. Which is recommended for cars with AW-1 recommendations
Bro, just follow all the maintenance as per your car's owners / users manual, which you got with it. The ATF will last at least 40-50K Kms.
Ok thanks guys i have just bought it zero meter it means i dont have to check it or get it change after 5000 kms as its done in manual cars.
Pls follow your maintenance schedule in ur car user manual that u got with it.Transmission oils in both auto and manual are usually changed every 40k km.Oil nd oil filter are usually replaced evry 5k km
Bro, this much interval is for engine oil change (not transmission oil).
Basit bhai manual transmission main first 5000 kms bad gear oil change hota hai and i was referring to it
Ok. I get it.
