if this happened after the trakker install then its possible that the tracking unit tech was sort of daft, he has tapped into the heater circuit wiring. Or has messed with the ground side of it.
In either case - suzuki techs should be able to test and write up this fault, which should be billed to trakker. The Karachi office has paid a lot of bills this way when they mess up cars. At first they will try to harass you, sometimes even put duress pressure of military etc. Get it in their head that they are responsible for this - you need technical proof for this which suzuki workshop can provide.
