@ mehranferrari
Dear global model of swift is with VVTI for 1.5 L engine only, 1.3 L engine is same as here M13A.See the specs below from suzuki global(:Swift:Specifications | Global Suzuki)
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TH colSpan=2>Model name</TH><TD class=unit> </TD><TD colSpan=3>Swift</TD></TR><TR><TH colSpan=2>Body Type</TH><TD class=unit> </TD><TD colSpan=3>Hatchback</TD></TR><TR><TH colSpan=2 rowSpan=2>Engine</TH><TD class=unit rowSpan=2> </TD><TD colSpan=2>Petrol</TD><TD>Diesel</TD></TR><TR><TD>1.3L</TD><TD>1.5L VVT</TD><TD>1.3L DDiS</TD></TR><TR><TH colSpan=2>Drive system</TH><TD class=unit> </TD><TD colSpan=3>2WD</TD></TR><TR><TH colSpan=2>Number of doors</TH><TD class=unit> </TD><TD colSpan=3>3/5</TD></TR><TR><TH class=functionTitle colSpan=6>DIMENSIONS</TH></TR><TR><TH colSpan=2>Overall length</TH><TD class=unit>mm</TD><TD colSpan=3>3,760</TD></TR><TR><TH colSpan=2>Overall width </TH><TD class=unit>mm</TD><TD colSpan=3>1,690</TD></TR><TR><TH colSpan=2>Overall height </TH><TD class=unit>mm</TD><TD colSpan=3>1,500</TD></TR><TR><TH colSpan=2>Wheelbase</TH><TD class=unit>mm</TD><TD colSpan=3>2,380</TD></TR><TR><TH rowSpan=2>Tread </TH><TH>Front</TH><TD class=unit>mm</TD><TD colSpan=3 rowSpan=2>1,470 / 1,480</TD></TR><TR><TH>Rear</TH><TD class=unit>mm</TD></TR><TR><TH colSpan=2>Minimum turning radius</TH><TD class=unit>m</TD><TD colSpan=3>4.7</TD></TR><TR><TH colSpan=2>Minimum ground learance</TH><TD class=unit>mm</TD><TD colSpan=3>140</TD></TR><TR><TH class=functionTitle colSpan=6>CAPACITIES</TH></TR><TR><TH colSpan=2>Seating capacity</TH><TD class=unit>persons</TD><TD colSpan=3>4(3-door), 5(5-door)</TD></TR><TR><TH colSpan=2>Fuel tank capacity</TH><TD class=unit>litres</TD><TD colSpan=3>45</TD></TR><TR><TH class=functionTitle colSpan=6>ENGINE</TH></TR><TR><TH colSpan=2>Type</TH><TD class=unit> </TD><TD>M13A(1,328)</TD><TD>M15A VVT (1,490)</TD><TD>D13A(1,248)</TD></TR><TR><TH colSpan=2>Valve arrangement</TH><TD class=unit> </TD><TD>DOHC-16V</TD><TD>DOHC-16V</TD><TD>DOHC-16V</TD></TR><TR><TH colSpan=2>Maximum output</TH><TD class=unit>kW/rpm</TD><TD>68 / 5,800</TD><TD>75 / 5,900</TD><TD>55 / 4,000</TD></TR><TR><TH colSpan=2>Maximum torque</TH><TD class=unit>N・m/rpm</TD><TD>116 / 4,200</TD><TD>133 / 4,100</TD><TD>190 / 1,750-2,250 </TD></TR><TR><TH colSpan=2>Fuel distribution</TH><TD class=unit> </TD><TD colSpan=2>Multipoint injection</TD><TD>Direct injection</TD></TR><TR><TH class=functionTitle colSpan=6>TRANSMISSION</TH></TR><TR><TH colSpan=2>type</TH><TD class=unit> </TD><TD>5MT/automated MT</TD><TD>5MT/4AT</TD><TD>5MT</TD></TR><TR><TH class=functionTitle colSpan=6>CHASSIS</TH></TR><TR><TH colSpan=2>Brakes(Front)</TH><TD class=unit> </TD><TD colSpan=3>Ventilated disc</TD></TR><TR><TH colSpan=2>Brakes(Rear)</TH><TD class=unit> </TD><TD colSpan=3>Drum, leading & trailing</TD></TR><TR><TH colSpan=2>Suspension(Front)</TH><TD class=unit> </TD><TD colSpan=3>MacPherson strut & coil spring</TD></TR><TR><TH colSpan=2>Suspension(Rear)</TH><TD class=unit> </TD><TD colSpan=3>Torsion beam & coil spring</TD></TR><TR><TH colSpan=2>Tyres</TH><TD class=unit> </TD><TD>165 / 70R14
185 / 60R15</TD><TD>185 / 60R15</TD><TD>165 / 70R14
185 / 60R15</TD></TR><TR><TH class=functionTitle colSpan=6>WEIGHT</TH></TR><TR><TH colSpan=2>Kerb weight M/T (min.)/(with full options)</TH><TD class=unit>kg</TD><TD noWrap>3D: 970 / 1,030
5D: 980 / 1,050</TD><TD noWrap>3D: 980 / 1,040
5D: 1,000 / 1,060</TD><TD noWrap>3D: 1,045 / 1,105
5D: 1,065 / 1,125</TD></TR><TR><TH colSpan=2>Kerb weight A/T (min.)/(with full options)</TH><TD class=unit>kg</TD><TD noWrap>3D: 980 / 1,040
5D: 1,000 / 1,060</TD><TD>3D: 1,000 / 1,060
5D: 1,020 / 1,080</TD><TD>-</TD></TR><TR><TH colSpan=2>Gross vehicle weight</TH><TD class=unit>kg</TD><TD colSpan=2>1485</TD><TD>1,525</TD></TR></TBODY></TABLE>
