I've some queries about my car and I got such good response on the last post so I thought o should ask here first before paying money to some mechanic.
I've 2012 Suzuki alto VXR
So I recently had radiator leakage issue which wasn't detected early in resulted in total sum of 50k (three times oil/filter bchange within 2 days, head gasket change 2 times and lastly ring piston) to different mechanic and the issue was resolved BUT I recently made a trip outside city (around 250km one way) and the car started to heat after doing like 100km so I had to stop the car and waited half an hour to let it cool down and then continue the journey same thing happened when I was on my way back. It works totally fine within city but on long route it show's it age (2012 Suzuki alto VXR). So my question is is it fixable or should I start considering to get rid of it?
second issue is it works totally fine but every once in a while it just refuse to start. I drive it almost daily and sometimes out of nowhere it just doesn't start until you push it. And usually it starts first time in cold mornings. Any idea what's the issue
and last there isn't any security system in my car which is concerning as the car sometimes stays out overnight. So kindly suggest a good security system I was going to go for Central locking system but I saw someone comment on another post that it's better to go for any security system as it also has central locking.
post is kinda long and if anyone reads it I'm thankful for your time and appreciate any advice. I'm from Lahore so if there's any good mechanic I can go there too. Thanks again
