Shukar Alhumdulillah After waiting for more then 3 months got my 1st every Self Import zero meter Dual Purpose Bike. Although its chines but The best bike ever made in/by china, as per company this bike during test run for 36k km after that every part was removed for check up, Result in the manufacturing of this bike. Here I want to tell to that Its not my 1st experience with best product of china, I spend 1 year with DP150 & find the best ever DHEETH bike manufactured by chines...Rest lets roll the pics
Tekken 250cc
Technical Specs:
Engine Type RE250
Displacement(cc) 223
Engine Model Name
Loncin 166ML
Carburator Model Name and Specification PZ30、Main Jet105#、Idle Jet30#
Bore x Stroke (mm) 69x62.2
Max.Power 12.5/7500
Max.Torque 17/6000
Compression Ratio 8.6:1
Fuel System
Carburetor, Fuel Tank, Fuel ****
Fuel Control
Plunger Type Carburetor
Ignition
C.D.I
Starter
Electric (Self)
Lubrication System
Pressure Splash
Cooling System
air Cool
Gearbox
6 Gear
Primary 3.33 1st Gear 2.909 2nd Gear 1.867 3rd Gear 1.389 4th Gear 1.15 5th Gear 0.95 Gear 6
Transmission Type Final Drive
520 Chain Driving Sprocket 16T Driven Sprocket 46T
Clutch Type
Oil-Immersed 6 Plate
Physical Measures
Dry Weight (Kgs)
132
Seat Height (mm)
820
Overall Height (mm)
1180
Overall Length (mm)
2100
Overall Width (mm)
860
Wheelbase (mm)
1370
Ground Clearance (mm)
260
Chassis and Dimensions
Frame Type
Crosstour
Front Suspension
Hydraulic Spring Shock Absorber,Total Length 845 mm, Loading Capacity (Single Shock) 89kg, Compression Stroke 115mm,
Rear Suspension
Build-In Airbag Total Length 375 Compression Stroke 47mm Loading Capacity 150 kg
Fr. Wheel Size
2.50 x 17
Rr. Wheel Size
110/90-17
Fr. Brakes
Disc Brake
Rr. Brakes
Disc Brake
Speed and Acceleration
Power / Weight Ratio
12.5\132
Other Specifications
Max.Loadage (kg)
150Kg
Fuel Capacity (L)
13L
Economical Consumption of Fuel
354g
Battery Type
7A
Assembling at Home:
https://www.facebook.com/mr.imraniftikhar/videos/10207978518524081/?l=3917085709891327665
1) 1st Ride Margalla Hills || 24 Sep 2015 || Post # 20
2) Eid Special Ride to Nilla Sand-Patriata-Muree-Kahjut || 25 Sep 2015|| Post # 21
3) Pir Chinasi || 10-11 Oct 2015 || Post 32
