Just wanted to share the specifications of K-Series Engine and Diesel Multijet.
Maruti Suzuki Swift
K-Series Petrol Engine Specifications:
<table class="x-varient-table" width="95%" border="0" cellpadding="1" cellspacing="1" align="center"><tbody><tr><td colspan="2" class="x-varient-header" style="border-left: 1px solid rgb(185, 185, 185);" bgcolor="#d3d3d3">ENGINE </td> </tr> <tr> <td width="51%">Capacity</td> <td width="49%">1197cc</td> </tr> <tr> <td>Number of Cylinders</td> <td>4</td> </tr> <tr> <td>Number of Valves</td> <td>16 </td> </tr> <tr> <td>Bore x Stroke</td> <td>73.0mm x 71.5mm</td> </tr> <tr> <td>Compression Ratio</td> <td>10.1:1</td> </tr> <tr> <td>
Maximum Power
</td> <td>85ps @ 6,000rpm</td> </tr> <tr> <td>Maximum Torque</td> <td>113Nm @ 4,500rpm</td> </tr> <tr> <td>Fuel Distribution</td> <td>Multipoint injection</td> </tr> <tr> <td>Emissions</td> <td>BS IV</td> </tr> </tbody></table> <table class="x-varient-table" width="95%" border="0" cellpadding="1" cellspacing="1" align="center"> <tbody><tr> <td colspan="2" class="x-varient-header" style="border-left: 1px solid rgb(185, 185, 185);" bgcolor="#d3d3d3">TRANSMISSION </td> </tr> <tr> <td width="51%">Type</td> <td width="49%">Five-speed manual, with synchromesh in all gears, one reverse</td></tr></tbody></table>
1.2L K-Series petrol.
Responsive And powerful-advanced 1.2 litre,16-valve K-Series engine
Great Performer - at 85 ps @ 6000 rpm and 113 Nm @ 4500 rpm, the new engine has improved compression ratios and delivers better initial and passing acceleration in city driving conditions for zippier overtaking.
Highly Fuel-Efficient - the 16-valve lightweight DOHC engine reduces friction and improves durability and fuel economy to be best-in-class at 17.94 kmpl**
More Comfortable Drives - A more silent engine with reduced vibrations. Lower NVH (noise, vibrations and harshness) provide an enhanced drive feel with lesser driver fatigue.
Lower Emission Levels - BS IV compliant, the Swift is greener and eco-friendly.
Low Maintenance Cost – The new K-Series engine means longer oil change intervals and improved spark plug life.
Maruti Swift - Specifications Petrol
Maruti Swift Diesel Vdi/Ldi with DDIS(Fiat Multijet CRDI Engine) Specifications:
ENGINE
Capacity : 1,248cc Number of Cylinders : 4
Number of Valves : 16
Bore x Stroke : 69.6mm x 82mm
Maximum Power :75ps @ 4,000rpm
Maximum Torque :190Nm @ 2,000rpm
Fuel Distribution : Common rail
Air Charging System : Fixed geometry turbo charger with intercooler
Emissions: BS III
Fuel Injection System : Common rail multi injection @ 1,400 bar
Drive Train : DOHC
Oil Filter : Green oil filter
TRANSMISSION : Type 5-speed manual, with synchromesh in all gears, one reverse
TURBOCHARGER AND INTERCOOLER COMBINATION
Efficient combustion.
Higher torque.
Cleaner emission.
5-STEP MULTI INJECTION COMMON RAIL SYSTEM@ 1400 BAR
Better fuel combustion.
Optimised NVH.
DOUBLE OVER HEADCAMSHAST(DOHC)
Precise & quick valve operation.
CHAIN DRIVE TIMING SYSTEM WITH AUTO TENSIONER
Maintenance-free for the entire engine life.
Precise valve timing.
16-VALUE CYLINDER HEAD
Improves breathing.
Cleaner emissions.
COOLED EGR SYSTEM
Cooled exhaust gas recirculation.
Cleaner emissions.
ALUMINIUM BED PLATE
Reduced engine vibration.
Minimum noise.
GREEN OIL FILTER
Environmentally friendly
Easy to maintain.
Maruti Swift - The Engine
