car is vibrating, cant figure it out
Please explain a bit! Is it vibrating on idle or when its moving at some speed? Write in detail so that someone could help you
It vibrates more on idle. When i speed up at like 60 it runs smoothly
Check its transmission and driveshaft as i also had the same problem and the issue was worn out 4*4 bearings
