Every owner keeps the vehicles as per their own mind-set of maintenance. You bought a 2nd hand car and not zero meter. So it doesn’t look decent to go back to the owner for every repair or every issue.
This is summer. You drive a healthy vehicle like 1-2 km and touch the bonnet after 5 minutes after parking it. You will feel that someone drove it from Karachi to Peshawar.
First check the coolant and it should be full.
Does you car has heat gauge ? if yes, then just keep an eye on it while driving. I should not go above than its normal position which is at middle.
And if it doesn’t has heat gauge, then there must be a sensor in the cluster. If engine overheats, the read light turns on in the cluster. If it happens, you have to pull over immediately and let it cool and don’t drive. Keep a gallon of water in the trunk just case of emergency situation like overheat.
