Please explain what do you mean?
150 watts in 220volt system is 0.68amp
150 watts in 12volt system is 12.5amps plus whatever amperage inverter will consume...
Thing is i have 900watt panels, 550amp batteries 12 volt system and i invested around 40k on 12v fans... But in these hot days those 12v fans are good for nothing..... My house is around 40 years old and it was made without any proper planning..... I need these 220v fans to run to keep using our solar system.....
So please suggest a cheap reasonably priced pure sign wave inverter which can run these 3 fans...
Can these fans be run by a UPS? I have 24volt apc 1.5kva ups...? I will charge the batteries by solar panels and somehow can i disable the charger of UPS? Can ups be only used as an inverter???
Sent from my SM-G530F using Tapatalk
