This picture is either made by some less educated person or misprint.
There is nothing like KV.
If power factor is 1 which is in very expensive systems than kva = kw.
Looks like in above picture they want to say how much capacity you need to run respective appliances.
If you really want some good solar system than calculate your critical load (you want to run on solar) wattage.
See thier max wattage on labels/stickers etc.
Sum all wattage = your required solar inverter.
How much solar panel you need? Its little tricky.
Total required watts x no. Of hours you want to run that appliances (say 8 hr loadshedig time).
This will give you_____ kwh.
Deivide these kwh with 5 (sun hrs) = solar pannels you need.
