I got same inverter in 24v with two batteries (CPS2200) and tried to connect two 260W panels in parallel but when I switch to Solar 1st mode in daytime and applied a load of 3 ceiling fans its drain battery while panels are producing ~12-13amps not sure why.
I think
Reading manual its mentioned that these inverters charges batteries at 20amps which they call "Ultrafast Charging" but in order to use free electricity from panels using this inverter you need to have at least 5 x 150W panels connected in parallel to generate ~20amps current. Charge controller in this model isn't intelligent enough.
Experts here can guide us.
