Can someone suggest.
Is net metering possible on single phase hybrid inverters? I heard net metering mostly requires 3 phase? I'm confused. If u have 3-phase meter, then single phase hybrid inverter is useless?
Most hybrid inverters I could find (5kw to 10kw) are only single phase.
Secondly,
When using hybrid inverter, if grid is off (loadshedding), does inverter run heavy loads like AC from solar?
Basically want the hybrid inverter to run AC on solar (when grid off), but if solar is down or not enough, then continue to run small appliances from battery, excluding AC which should not drain the battery.
Hybrid inverter options I could find for 5kw/10kw:
Inverex Nitrox (local)
SolarMax Onyx (local?)
GoodWe
InfiniSolar (local?)
Not sure which one should be chosen.. (EDIT TO ADD: should have low/NO fan noise, preferably fan-less cooling)
@saqibhassan95 @centos @AkbarGr8 @umans
