Dear first of all, the key thing to installing and running a solar power system successfully is the education behind designing a system, with regards to its capacity, and selecting the different components of a system, i.e. features and specs of the solar panels, charge controller, inverter and battery bank. Please note the following
- Solar Power System is NOT a cheap alternative to electricity. The cost is for selling reliability.
- Peak Load and Backup Time are two different things that affect the cost and components.
- Lead-Acid Batteries are NOT suitable for Solar Power Systems. They will perform, at best, for a couple of days before they become useless.
- UPS systems are designed for backup only, not power generation. A Solar Power System GENERATE electricity in its own way, and combining a UPS is not the right way.
- An electrician or a sales man CANNOT design and sell you a system, it will not function properly i.e. handle the load of your devices and provide you the required backup. This is what is happening everywhere these days (Township, Hall Road etc.).
- People should focus on buying a SOLUTION and not individual components – costlier, but reliable, and you get after sales services as well.
Depending on your needs (peak load and backup), a system can cost as less as 150K or as much as 250k. Someone selling for cheaper than this, is selling you a poor quality system that will not give the required backup, and there will be no after-sales service.
On the other hand, if it is more expensive, then you are being sold a VERY good system, but greater than your needs and required.
Your requirements and budget should match each other. There should be a balance between the two.
Examples:
- With a Peak Load of 500 Watts, and backup time of 3-Hours (minimum):
If you experience load-shedding for up to 3 Hours at one time, then the above should be your requirement – cost will be around 175k
- With a Peak Load of 500 Watts, and backup time of 6 Hours (recommended):
Same as above, but the number of panels, batteries and charge controllers will be designed for a longer backup (accounting for load shedding, overcast days, etc.) – cost will be around 250k.
If the above makes sense to you do let me know, I will guide you further on who to contact, how to buy and from where.
