Yar, this is not possible, neutral has to remain connected to wapda, further, at maximum, you are using off-grid system, which means, live wire from inverter will only power the connected load. in case, if you have not run the neutral with the live wire, try disconnecting the neutral, all your loads will turn off.
your consumer meter shuts down during load shedding, they have internal rechargeable battery, which keeps the display running just in-order if someone wants to read the units or least time and date settings remains intact so meter can carefully track your off-peak and peak timings and register the units for said zones.
otherwise, meter is practically off and measurements sensors on meter is connected with live wires only. Neutral in most cases is pass through.
