It can be harmful as all the neutrals should be common, which implies Neutral from Inverter be connected to the Neutral of Home. No Need to Run two wires, just combine the neutral and Earth at junction box and run live wire across your Home.
At times, electricians make mistake of putting the switch on Neutral, always make connection with Live wire. You may have to check every individual load to catch the mistake.
