And you are right about invetrer,its not hybrid,its just UPs with charge controller and with automatic shifting.why i say it?
because in picture i posted the solar mode in which it bypasses the batteries doest work in this inverter.so what happens is that batteries are being used and charged all the time,if load in more then they start draining and if this happens when sun is going down and PV input is not enough, it doest charge the batteries enough.so at sun set when it shifts to Wapda it charges them from almost zero to full taking lot amperes feom Wapda (which will make wapda bill more and more) and if at that time loadshedding is happening than its blackout in the house
we have suffered this black out once and this is the reason i am returning this inverter back.
So my advice to all is that dont, buy inverters with this menu.(an update,an electrician who installed same 5kv inverter(mine is 2kn,so i think there may be problem with ones using older software) claims that he see the required mode in 5kv inverter,so its upto you guys to confirm it before buying these type inverters)
they will end up your batteries very soon and you may suffer from load shedding as well, inspite of spending so much on solar system. i came to know this problem as my battery bank was small.these companies install a large battery bank so that when sun goes down the backup time is more and so user dont experience this.if company sells you this kindly ask them to return inverter if this mode wont work.(this pic is from user manual of my inverter)
and believe me i tried my best to work this mode,even when batteries were full and on just one energy saver,it did't shift to this mode,so it means at that time all the solar input was being wasted.only this mode happens.
you can see solar input to batteries and than out,not bypassing.at this time load shedding was there so this showing no AC input.this time batteries are not full but same mode continues when they are full..
Instead buy ones with menu looking like this,these are true hybrid inverters.
awww i am so sleepy.i did this post in more than an hour after fajar and now its 6.51 Am. but i hope this help others
