The only problem with these UPSes is that their charging rate is fixed. Homage introduced Hi-Low charging speeds of 10&20amps but the difference is too big.
Formula of battery charging speed is total battery amperes/10
the osaka battery you have bought has 135 written on it but its actual amperage might be mere 110, 105amps hence you need 10.5 or 11 amp charging speed.
Now 10 ampere speed is too low for the kind of load shedding we face here... but 20amps speed would be too high!
In locql UPSes, which are now available with all kind of goodies the charging rate is adjustable by just turning a screw on the chip.. you can set 15amps in summers to help ur batteries coupe with extreme loadahedding and set it back to 10 during winters.
bdw.. if u want an inverter than try cyberpower.. its a better built than homage
Sent from my HUAWEI G700-U10 using Tapatalk
