i believe strongly on...
Cost may depends on the Market and time of purchase.. but any way...
In March-2014, i installed this DC setup...
100 Watts Panel was for Rs.8500/- (2 x 8500=17000/-) but recently someone told me 240-250watts panel is for Rs.15000/- and i think this one panel is enough for 1 fan & lights system (Actully one room setup for 20-24 hours).
Single core Cable 6mm - Red and Black 2 coils i purchased for Rs.2500/- (for 23 meter roll) but new info is that if someone can hunt Balal-Gunj-Lahore or Badami-Bagh-Lahore, he may find a good quality n cheap imported cable from there.
Charge controller (PWM 20Amp ep without LCD was 3500/- but i purchased bigger 30Amp with LCD display for my checking and mental satisfaction for Rs.5500/- its brandless but good quality) this 30Amp can support upto 400Watts.
DC-Fan was for Rs.4500/-
DC Light was around for Rs.200/- each (but last month when i visit Hall Road, Lahore almost same Light 10Watts+12Volts was for Rs.90/-)
My Lights use 1Amp per hour but we hardly use 6-7 hours as not always both lights are on... so approximately it will be 8-10Amps per day.
My fan mostly work for 10-12 hours and thats 1.8/2Amp per hour x 12 = 20-24 Amps consumption...
if u use Fan for 24 hours it will be 48Amps maximum. but i wont suggest to run anything 24-hours continuously.
Cause defiantly every thing needs a break in 24-hour working circle... so if you are using it for 20-hours, it will be consuming max.48(40)fan + 10Lights = 50/58Amps on a 12Volts battery in a full 24-hours...
And as i am getting 40-45Amps per day from 200Watts panels and also when my panels are quite far (around 75feets) from my charge controller/battery and even my cable is only 6mm (100%copper local made)... anyone who may use a good cable around 10mm or by shorten the length of cable from 75feet, will get more Amps per day..
One thing more i will suggest about purchase of battery, always try to get the actual Battery AH double then your consumption.. i.e. if u want to use 60Amps in 24hours, get a 120AH battery... this is good for a battery life and also in case of Cloudy/Rainy day, etc. when we have a less generation from panels.
Also check the battery's actual AH-Power the models printed on a Wet-Battery is not the actual AH... e.g. AGS-GR-85 battery is not a 85amps (as normally we ppl told by shopkeepers), its actually 70AH battery.
My Battries for this DC-Setup was free... or you may say for Rs.3000/- (the scrap rate that i was offered by battery-shopkeeper) because initially i used old batteries of my UPS, those were not giving me sufficient backup through UPS..
With new batteries when my ups is running for 2hours backup, these old batteries were giving me backup of just 15 mins, so for me these were total scrap with UPS setup. but after shifting same batteries on DC-setup they works OK with me for 12-hour fan running and lights since last year.
Now with all the rates it looks like its a HUGEEE expensive setup...
but look from the other side...
WAPDA ... Load Shading ... Always tension of Load on UPS ... UPS tripping for Long shutdown ... New batteries for UPS every year ...
1 Room : DC-System
Fan is little low in air flow.. but
Light is ok..
Batteries Life is more then double or at least double..
the consumption of DC-system is quite low as compare of AC-System (my personal calculation is AC-fan consumes 4/5-times more)
instead of buying a New-UPS with battery (if solar panels are out of budget,) buy a good battery charger
this time, and next year instead of new battery purchase, buy a solar panel cause your same battery will work with solar but not with UPS. and the cost of WAPDA you pay for charging a battery daily will be much more less then you have to pay in case of UPS-setup.
I m not an expert.... Please correct me anytime....
