(actually my pwm controller can show me the total numbers of Amps i received and used during a specific time period, but my mppt cant do that)
my program to connect the panels in series and connect them with mppt-controller... this way i may use a thin cable (low amps+high voltage=minimum voltage drop plus the efficiency of mppt)
But this mppt controller is not showing me how many AMPs i get in a day from my panels...
Meanwhile my pwm controller has an option to calculate the total number of AMPs received from panels as well as the AMPs out for load.
So if i able to connect the output of my mppt-controller into the input of my pwm-controller and the output of this pwm-controller connect with my ups batteries, i will get the maximum efficiency from panels as well as able to calculate the AMPs i get from panels on daily basis. (Panels --> MPPT --> PWM --> Batteries)
This will also help me to find out the actual efficiency of my mppt-controller and the effect of connecting panels in series over the same cable in a practical world (other then calculations).
