i am not an expert but my personal Experience is...
As you have a load of 4/5-Fans and 2-Tube Lights first of all i will suggest to replace your lights with LED-bulbs (more economical in consumption even compared to Energy savers) ...
One Tube Light's consumption is almost equal to a ceiling fan.
For ceiling fans also check the consumption individually, cause with the passage of time capacitors of fans gone weak and need to be replaced after 2,3 years.
And for the Choice of UPS, keep in mind that never ever go more then 70% of UPS-powers.. e.g. if u have a load of 700-Watts get at-least around 1000-Watts UPS.
Never confuse between Volts & Watts... if UPS is 1500-VA it means around 1000-Watts.
I always prefer 24V-UPS that is 2 Batteries connected in serious and giving backup, rather then 12-Volts (single battery).
Always try to manage/reduce your load as much as you can for UPS...
Remember for a UPS/Battery when you are using maximum backup the life of battery effects a lot. so i prefer the batteries not too big (as AH increased its cost increase), and replace them at the start of summer season every year. cause mostly in our setups we need more for fans in summer as compared to lights in winter.
Personally i am using APC and Compaq UPS since 4-5 years..
At a place where i have double cable wiring, i am using APC-refurbished and its working fine. 1 more advantage of APS, its charging may be increased at some extent by local-intrusion.
At a place where i have single cable wiring, i am using Compaq-refurbished and its working fine. its charging may not be increased but one can use external charger if required due to extra ordinary load shading.
by my other friends experience ... Good Desi-UPS is better then other ones i.e. aurora, digital, homage (all found to be problematic after or within 1,2 years) and need to be discarded. but Desi-UPS are repairable.
currently i am using APC-1400VA xl with two Millat-M105 (70AH) batteries, and in day time 1/2 fans and few lights and before 11 at night my ups is totally charged my batteries, and at night 3/4 fans and facing no problem till now.
Now choice is yours...
if u want to spend more at one time, i will recommend APC/Compaq (for sure i am not publicizing anyone here, just advising on my personal experience.)
