No idea about that, may be some expert may REPLY for that.
- if i switch off the grid in day time then the solar input via mppt will charge the batteries and the ups will also REMAIN CONNECTED to the batteries - the load i.e. fans etc will directly run on solar power plus batt will also be charged..
yes... but if you have enough solar panels for your load as well as for charging the batteries.
- in the evening, i have to switch on the grid power otherwise the ups will drain my batt to the maximum extent..
Yes. exectly.. as soon as solar generation low down from your load.. your batteries will start draining. just simple maths.. if u are generating 5amps from solar and load is 8amps you are using 5 of solar + 3 from your batteries (cause grid is not switched on yet)...
- if i didn't disconnect the grid, my solar power will be lost or not??
Not 100% in Pakistan.. we always have a Load Shading schedule on daily basis.. whenever there is a load shading (grid off automatically/manually) solar will be providing power to your batteries as well as to your load (once again reminding you, iffff you have enough solar panels).
its simple if u have charged batteries with your ups and solar is generating power even there is no need at your batteries end.. the efficiency of solar will be down and this is a controller's auto function (provide as much as required).
