Its a new setup only 2 months old. Before this setup my average bill in winter is 4000/5000. After this setup last bill I received is 2200. Next bill with energy calculation will share. My hybrid inverter also had an energy calculator in it but due to experiments it was reset several times and right now no record available. Payback is 2nd priority brother ..... bijli to mil rahi hai especially in day light you wont need to worried about load shedding. Before this setup I was using a PWM charger with my Eltek Sine wave 48V UPS. I was not satisfied with PWM charger also I was using heavy cables from roof to battery bank location because PWN charger are low voltage but in the MPPT controllers are high voltage. Difference is given below.
(Pulse Width Modulation) PWM Controllers: a FET switch is used, under control of some algorithm, to rapidly connect a power source, to a battery. The switch "makes" and "breaks" many times a second, to control the charge.
When the battery is quite low, the FET switch is ON, and the panels are connected directly to the battery, and since PC panels are a "current source" their voltage drops (or is pulled low to the battery voltage) and some power is lost, depending on the difference of the Vpmax of the solar, and the present voltage of the batteries.
PV voltage - Battery voltage = Difference x Amps = Lost wattage
Note if the array was a 200W array, amps would be 11.11Aa
18V @ 11.11A = 200watts
18V PV - 12.2V battery = 5.8V @ 11.11amps = 64.438 w lost
MPPT Controllers: [Maximum power point tracking]
a more sophisticated circuit is used, much like a "DC Transformer" to dynamically convert the power source (water, wind generator or PV panels) via an efficient DC-DC conversion process. This can also down convert high voltage DC, to suitable charging voltage for the battery, with very low losses, about 95% efficient. This is a good thing if you have a remote array - you can run high voltage DC to the controller and avoid expensive high amp wire, and incur lower losses.
The MPPT advantage vanishes when the controller switches from the BULK charging mode, to ABSORB, and does not need the extra power recovered from the conversion process, and falls back to PWM for ABSORB and FLOAT stages. This can be managed in different ways for individual systems, as many MPPT controllers have user programmable settings.
