ags................
@ muh_Farooq
Is the infini using wapda with your settings. have u checked with the Amp meter.
Dears. I have asked for system to support my 600watts ups using 125 amp narada battery. The dealer who is my friend have to provide me 150?2 panels and frame and charge controller 20Amp.. with brackets cables and frame for panels worth 35k. aims is to use day light only. no long backup needed. this is pic of charge controller. is this controller good as compared too MPPT. panels are chinese
the controller picture
For how much u got this infi inverter for and have u seen any impact on wapda bill?
*- 120,000*- i hav un-interrupted supply all day despite of loadshedding, main advantage- my solar gives me 12- 14 units daily. Suppose 12, 1230=360 units/ monthIf unit rate is 15, 360*15= 5,400
I hav checked. No wapda usage
[I]@ muh_Farooq
[/I]Bro 4 questions
@wiki09Bro 4 questions
Why have you changed this value
to keep batteries maximum charged, when grid is available
How to extract data from infini software ..... ?
when inverter is attached, all data is loaded in software, where u can access
Can u paste the pic of infini lcd screen during day time
4. With your setting does your system work in hybrid mode. Mean at morning and evening does the PV energy and grid combine to fulfill your AC load
In hybrid mode, units generated remains same ie 12-14But inverter uses grid as well to manage same load, this means less savings at the end of day
Example 01
Example 02
Mode is hybrid. Infini not using solar at its peak, and Wapda is being used at same time
hi friends. can someone suggest solar panels brands/companies ratings available in Pakistani market which are considered good and rates idea. . also LCD type charge controller. I have booked above system to utilise solar energy during day time only. feedbacks will be highly appreciated
Thanks @ muh_farooq
I thought it completely eliminates the grid. Thanks for the example bro.
Any idea we can feed back to grid, any news for smart meters in Pakistan
Smart metering has been approved by the government, but unfortunately there is no sign of implementation yet.
Where in KARACHI can i buy wires which are used by UPS people??? ....i am talking about red and black wires used to connect battery with UPS
............................Only use filtered Air condition (AC) Drained Water for battery Laval Control.. Collect the AC drained Water in mini Drum.. u can us this water in ur Car's radiator.. this is pure 100% water without minerals..
............................You should go to Shair shah.. and purchase old model Dip made APC used UPS.. never purchase SMD made APC UPS.. .. every thing available in Shair Shah..
I only need wires
In Shaire Shah (تار مارکیٹ) Wire Market u can find Imported DC and AC pure coppered wires too in every size and type.
