A Magical Device that can save fuel up to 45%, installation is very simple just connect one wire to battery negative terminal & other to the Radiator body thatz it.
Fuel Saving Kit (Petrol) at Best Price Rs. 26,250 in Pakistan (Karachi Lahore Islamabad)
Quick Overview
It's a Japanese technology with life time warrantee, which can be use to control vehicle fuel consumption & increase the pick with 45% fuel saving, its easy to install in your car, you needs only two terminals to connect the Fuel Bank EVO II. First connect to one of the Fuel Bank EVO II's terminals to the negative bettary terminal. (Since the Fuel Bank EVO II does not use positive-negative polarity, you can enjoy the same level of performance no matter which terminal you use. A picture is attached for a quick view of its installation.
Fuel Bank EVO II Petrol Kit
A large amount of static electricity is generated by friction in various parts in the car. Being electrostatically charged, the flow of the liquid and the gas is disrupted and prevent the smooth flow of the electric current. Therefore the efficiency of the heat exchange and the combustion goes down and the complete combustion is preveted. By the +/- characteristics of electricity, Fuel Bank EVO II neutralizes the static electricity with which the car is charged, makes the combustion closer to the complete and brings out the performance which the car has originally. It improves not only the power and the fuel cost but also the tone quality of the audio, and even the shift feeling and the ride quality. And it has gotten more difficult to install after-sales parts on latest cars which have become black boxes. But to install Fuel Bank EVO II is only necessary to connect the terminal of this device to the minus terminal of the battery and to the body earth. Fuel Bank EVO II is the epoch-making item which can draw out the potential of the car totally and maximally. Please experience the performance by all means.
Please connect Fuel Bank EVO II to the minus terminal of the battery and to the radiator core parts. And then if you just fix it, the installation is completed. It is very easy. In additon, if you want to value the power-up, you may connect it with the throttle body to make it act directly on suction air. Because the double-faced tape to fix the body and other items are also bundled, all troublesome things are none. The gold-shining body is also very effective in dressing up your car.
It is the characteristics of Fuel Bank EVO II that it is possible for the users to feel the effect clearly as soon as they install it. We have also got the surprizing measured results showing the excellent improvements both of torque and power when we measure the engine power with Dynapack (which makes the margin of error smaller by getting the output from the axles directly). In addition, that is not only the improvement in the peak power but also at the whole area from low rotation to high rotation. This gives the excellent experience.
