You Just Posted Same Thing 3 Times My Friend....!
B.t.w Praise To Your EC1 As The User Hameed01 Just Tried A Better Built(Atleast Exposed) Setup On Modern ECU Like Vitz...And It Simply Neglect The Effect....He Posted It Clean And Clear And ALso Hook Up oscilloscope To Confirm It.....! Yes He Told It Clean It Clear As It Was Expected I Will Happen.....
The ECU Have Many Ways To READ ANd Revert Back Your Changes My DEAR .....! As I Said Earlier Some 90's ECU Might Fall In Trap With It And That's ALso If You NEED.....They Can Still Be Make Work Better WIth OEM Setup If Provided Working Sensors.....!
Let Me Give You An Example Of Pre 00' ANd Post 2000 ECU's
Pre 2000's Are Like One Face DRAGON......You Cut Of One HEAD....You Can Make It DUMB
The Post 2000 ECU's ARe 12-14 HEaded Dragon Which Flies.....It WIll SIMPLY KILL You Before You Cut Other 12 Head.....
So Its Useless To Mess With These Intelligent ECU's UNless You Get Into Roots Of These ECU's MAP's.....They Are Built Quiet Intelligent
What People Do Is Replace Them With STANDALONE For Their OWN COntrol....That's When They Want Performance...ANd Have Real Upgrades In Hand....
Its Simple ....You Need To PLAY??? You Got To Pay Buddy
In SImple Words...You Need Economy OUT OF IT..??? You Need To FOLLOW Their Rules And Have To Provide The Required SENSORS....Else Bear With The Consequences.....! They Are Based On MAF/MAP And 02 Readings Backed Up With Almost Every Other Sensor Out There On Your Engine.......
EVen The Expensive PIGGYBACk ECU's Fail In Many Places...!!
