How should I approach this problem? Should I change the front tyres or all four?Suggestions?
Change Only front
How many kms have you run the tires?
30,000 since I have bought it! Total milage is 105000, I'm not sure about any prior tyre replacement.
Have you rotated tires front to back?
And is your car alignment correct or did you have it done to offset the caster angle difference? I used to see this regularly in Pakistan.
I have not checked that, neither have I changed anything in that regards! The only thing that I have done to the car is oil changes after the required intervals!
Along with oil changes, you need to have tires moved from front to back to even out wear.
