Haha...yeah he did.Thanks for the kind words bro...
(Y)
So am I...
Well they were forced into it
Yes I love them too <3
Lenso S2!!!!
Thanks love,yes that's the whole purpose this time. =P
You've inspired me to get off my lazy *** and post some pictures for a change.
Kya baat hai celebrities bhi... =P
Hmmmm....k
(y)
Hahahaha...true story.
Yes,one step at a time sir and thanks for the kind words.I'm still not over it.
Janu...wait,kero naaa!
Thanks sir,actually it was the other way around some stories are best told by starting off with the end.
A never ending struggle ehhh....
Without further a due let's start off...
The Subwoofer:
Infinity Kappa Perfect 12 VQ
The Infinity Kappa Perfect 12.1 12" subwoofer joins together a rugged aluminum cone and high-roll butyl-rubber surround to produce impressive bass all the way down to 18 Hz. The ultra-rigid woofer cone won't distort (even when you push it to the max), but it's light and responsive for remarkably high sensitivity. That means it'll squeeze the most volume out of the power you feed it.
The massive cast-aluminum basket and the pole-piece are vented, so the 4-layer voice coil stays cool when the music gets hot. Infinity subjects these subs to the most intensive testing in the industry ? 100 grueling hours of performance at their full RMS rating (350 watts).
The Perfect 12.1 bridges the gap between subs intended for SPL and those intended for sound quality, creating bass that hits hard and sounds great. Whether you're planning a competition system or just looking for powerful bass, this sub's ready for action.
- 12" Single 4 Ohms Kappa Perfect Series Subwoofer
- Power Handling:
- Peak: 1600 watts
- RMS: 400 watts
- Impedance: Single 4 ohms
- Magnesium Metal Matrix (M[SUP]3[/SUP]D) Woofer cone with curvilinear design
- Large-roll nitrile-butylene rubber surround
- Bumped and vented pole pieces allow for 3 different motor strengths and performances
- Cast-aluminum basket
- Integrated front gasket
- Proprietary die-cast aluminum basket
- Single 3", 4-Ohm Voice coil
- Frequency response: 23-400 Hz
- Sensitivity: 89 dB
My take on the sub:
Put it in a 1.25 cubic feet sealed enclosure and let it rip.It can pound as hard as any of the other subs out there and vanish in thin air,it's so stupid that sometimes I need to turn it off to see if it's even working or not.Perfect for components that can't be crossed low because this little sucker blends perfectly.In the budget IMHO I haven't seen a better sub and I dare say it gives subs priced 3 or even 4 times itself a good competition.
p.s I haven't even given it a monoblock yet.
Pictures:
Autoleads G9-S425-10.-10mx2.5mm Twin Flat Speaker Cable
Pictures:
More updates to follow...stay tuned.
Cheers...
