And if something was left to be described about this bike, here it is:
The critically acclaimed SUPERBIKE is the world's first turbine powered street legal motorcycle in its class, and has been recognized by Guinness World Records as the "Most Powerful Motorcycle Ever to Enter Series Production" and the "Most Expensive Production Motorcycle". Powered by a Rolls Royce Allison gas turbine engine, the SUPERBIKE has demonstrated over 300 hp and 425 ft/lbs of torque on the Dyno Jet 200, and has been representing the latest in engineering technology, the bike features carbon fiber fairings, a rear-mounted camera with LCD color display, forward-and rear-looking radar detector with laser scrambler, one touch "Smart Start" ignition, and more. The MTT Turbine SUPERBIKE is starring in the Warner Brothers movie "TORQUE", and Men's Journal lists the bike as one the most "awe-inspiring, innovative, and otherwise amazing designs" in their feature article "Perfect Stuff".
Engine:
Rolls Royce Allison
250 series gas turbine
Power
320 HP @52,000 rpm
(286 HP @ rear wheel)
Torque:
425 ft/lbs @ 2,000 rpm
Output RPM:
6,000 rpm
Compressor Speed:
54,000 rpm
Weight:
500 lbs
Frame:
aluminum alloy
Fairings:
carbon fiber
Rake:
27 degrees
Seat Height:
31.5 in
Wheel Base:
68 in
Wheels:
17" carbon fiber, Dymag
Tires - Front:
120 60ZR17, Pirelli
Brakes:
3x320 mm floating system- 4 piston
calipers, Brembo
Shocks:
mono-shock adjustable
oleopneumatic, Ohlins
Front Forks:
55 mm inverted
Fuel:
diesel, kerosene
Fuel Capacity:
8.5 gallons (34 liters)
Lubrication:
dry-sump/3.5 quarts turbine oil
Transmission:
2 speed automatic
Rear View:
rear mounted camera with LCD color
display plus side mirrors
Seat:
single or double
Colors:
infinite custom colors
Let it end here now.
