Salam, Mr. Baleno and all users of baleno
Please help me in solving this prob.
I have recently purchased baleno 2003 and driving it since 2 months. i have no experience of having and maintaining baleno in the past. The car has start to make troubles.
- All mechanics / Electricians told me that your car has bad wiring and you have to replace wiring in a due course of time
- From the first day car give very low pick up on 2nd gear, mechanic tried to solve this problem by setting cng. he made the pick up was better but after some days the problem started again.
- it also started to give bumps jhatkay.
4 some times when i switch it the, the check engine light started to blink.. instead of stable (normal). and the does not start. however after giving it ignition sever time. the check engine light suddenly stables and the car starts.
- Car gives whistle sound when shift to the 5th gear? it gives a very loud sound of whistle.
now the proble is Crank shaft sensor?
Pulleys under the timing belt ?
Air Filter?
CNG setting?
Gear box?
My mechanic told me the car has a weak crank shaft sensor and pulleys are also need to be replaced.
Secondly he also told me the whistle sound is becuase of gear box.
Please guide me. i can not spend alot, having a low budget
