Dear Fellow Pak wheelers, I have just recently bought a baleno 2005 model and found out that its gear lever seal is leak like I can see a small drop every morning underneath the car. mechanic says gear box has to be opened for fixing it. should i go for it or should i keep using it as it is. Please help. Thank you.
Gear seals needs to be changed. Gesr box khulay ga
Many thanks for prompt reply.
salam abid how r u, regarding plug coil which was advised from you and yesterday i changed it from chota gate i buy this side wali coil of Rs. 4000 and also installed it. now car is in running on cng in smooth but i think need to get the some cng setting from mamoo... Thanks for the support. power staring working accelator otherwise hard please advise inthis regard.
Uploading...
Ye walay coils?yes go to mamoo for cng setting
Asalam o Alaikum, I have a 2001 Baleno and I want to install an aftermarket RPM meter in it. The electrician tried hooking it up to the coils for reading but he failed. The rpm meter is in perfect working condition. Kiaa aap mai se koi muje guide karsakta hai k kaise install hoga aur agar kisi ne karachi mai lagwaya hai to kaha se lagwaya hai. Please guide me as I purchased the meter for 4000rs.
abid i need suggestion for stearing problem, accelator per soft hai otherwise too much hard.
power steering oil dekho poora hai pehle?
ji bro oil pora hai but stearing bohat hard hogaya hai accelator dainy per soft hojata hai, please advise what to do or if u have any specialist for power stearing pls let me know
Power steering pump ka kaam hai i suppose. ashfaq k samnay suspension wala hai Imran Engineering k name se - wahan chale jao, wahan owner nadeem hai, mera name lena (abid bhai Liana walay) and take his advice
my denter just completed his work, now car is ready for other work, so now i want to get axle work done, as its making tak tak tak tak sound on turning, any idea how much will it cost?
go for NEw axles (outers). dont buy used from suspension wala no matter how much he force you. NKN brand new Japanese are available for ariund 6k or so a pair. go for them eyes closed.
thanks @abid110 i will get them today, can you please tell me how to restore steering original color, the color of dashboard is ok but steering color is little faded and little pale, how to fix this?
rehne do aise he - mera bhi faded hai
abid bhai maira stearing ki problem ka solution batado pls its too much hard, or jub accelator do to soft hojata hai
Bhai read my above post. I told you where to go
Guys please review this, my mechanic gave me this estimate.
Assalam o alikumfriends i am thinking to buy a 1998 model baleeno from a friend. car is nicely maintained and engine is in good condition. I was looking for a good cultus(around 2005) when i get that option.My main concern is spare parts availability and m,maintenance. as the car is about 20 years old surely it will be needing maintenance regularly.i want to ask baleeno owners that how do you rate ease of maintenance of this car on a scale from 1 to 10 (1 hardest, 10 easiest) as compared to cultus.and how much should i pay him?
For karachi, do not pay over 350k. Maintenance will be easy and not expensive. Issues if too technical can be mishandled by mechanics.
Itnaa kaam???
