@atharkhan87 waise overall baleno kaisi chal rahi hai? Mazedar?
yar wiper arms used with blades mile 1000 k plaza se, 250 ka spendil mila new aluminium ka, original plastic ka tha jo mil nahi raha tha to locally made lelia alloy ka 250 mai
achi chal rahi hai so far, i am enjoying it.... do dfa highway pe leke gya hun... bas zyada duur nahi gya, inshAllah november mai pakistan tour pe jane ka plan hai... lets see
Wah... Me bhi jaunga baleno per apni kabhi na kabhi Mazedar car hai waise... Tyre 13 hain?
Any bro help me...My baleno 2005 model when started in the morning gives some smoke for 3 to 5 minutes but later on will not show any smoke .engine oil level will also reduced but vrry little.driving is smooth.What its mean?
My baleno is giving smoke on startup for only 2to 3 mints and then become normal.driving smooth.Engine oil level very little decrease on changover.Then wat its mean to give smoke on startup?
Shot valve seals common issue with baleno and efi cultus
It must be white smoke in the morning...? If yes its the issue as mentioned by Saboor above
If the smoke is white, the Valve seals need to be replaced.
yes 185-70-13
Yar valve seals kese replace hon gi.how much its cost.kiya pora engine overhall ho ga.
Aise he chor den not a big issue
Any good reliable mechanics for Baleno in Islamabad? For small basic things such as minor electric problems. The mechanics that I used to go to are now becoming choorai plus, they are not neat when doing their work.
What problems are you facing discuss here for precise answer (hopefully) so that you hit the right place to work upon
Just a minor one. The rear left door does not lock or unlock with the central locking System. You need to press the button 3-4 times to lock/unlock it.
That is a minor issue. Just go to any lock maker he will readjust lock setting in the door
I did go to one. He wasn't able to fix it. The lock seems to have become a bit stiff. Thinking of doing a DIY myself (with WD-40)
Bro in my baleeno,coil k neche jo holder hai wo short hai , separate mil jaye ga ya pori coil change ho gi.
konsa holder?
I think you're talking about the plug.
