Dear All,
My friend was facing missing issue in his baleno 2004 both on petrol and CNG. He changed almost everything but still facing the same issue. 2 days back he contacted me for help, so I suggested him to completely remove CNG wiring and set his car on petrol. Now his car is completely on petrol and CNG wiring removed completely.
Car is tuned and now working very fine. But issue is the check engine light continously ON and was observed by me. I asked him about it but actually he is not sure that this light was previously ON or not.
Then we connect the scanner to check the check engine light issue but no issue observed means all codes removed/reset but still check engine light is ON. The electrician (my friend) told us that ECU is faulty and also as per him it is repaired already and I think he is right as we replace each and every sensor with my car and also complete wiring is checked thorougly.
Now what you people will suggest? After changing ECU, what about IMMOBILIZER??????? Actually ECUs are available in Shoba and also we will change complete wiring as wiring condition is very bad but as per electrician after changing ECU immobilizer will not work and we dont want that.
So need sugestion regarding this..... Thanks......
