Most of us want to get the most out of our cars as they start to age. For this, you have to keep checking the health of your car's parts to ensure everything is in perfect shape. Improving the life of the parts of your car can help you avoid high maintenance costs and retain the value of the car in the long run. Spare parts can cost you a lot, especially different engine and suspension components if they get faulty over time. Taking care of these parts is not a cumbersome process if you check them on a regular or routine basis. Following is a list of the ways in which you can extend the life of your car's parts:
Optimal Tire Pressure
Always make sure that your tires are at the optimal or recommended air pressure. There are many benefits to keeping the recommended amount of air pressure in your tires. Fuel efficiency gets a boost, and the wear and tear of tires are minimal. Moreover, road grip and handling improve as well, giving you more driving pleasure. If the tire pressure is lower than the recommended level, then there will be more heat accumulated on the tire. This is due to higher resistance from the road that heats up the tire. According to an estimate, if the tire pressure is 2 psi lower than the recommended level, then the fuel economy drops by almost 2 percent, and the life of the tire drops by almost 6,500 km. If the tire pressure is more than the recommended level, then it is difficult to handle the steering of the car. The chances that your car will skid also increase, and the level of comfort decreases.
Rapid Acceleration and Hard Braking
If you rapidly accelerate your car and then brake it hardly, the component parts of the engine and braking system get worn out quicker than they should. Brake pads and discs get more wear and tear. Fuel economy also worsens, and, on sharp turns, the tires get damaged too with time. Also, make sure that your car is at a complete standstill before applying the first and reverse gears. Otherwise, your gear system can get damaged if you frequently apply these gears while the car is still in motion. Always try to accelerate the car smoothly and brake it from a distance so that you do not have to brake hard. This will also lower the probability of your car, hitting an obstacle. Braking hard is also detrimental for your tires as they get heated unnecessarily, which results in their wear and tear.
Make Use of the Parking Brake
What some people do is park their cars without applying the parking brake and engaging the first gear. This puts a lot of pressure on the gearbox of the car, especially if it is on an inclined slope. This undue pressure can brake components of the gearbox that can be very expensive to replace. Applying a parking brake just takes a few seconds, and it can save you from a lot of hassle in the long run. Also, make sure you have properly disengaged the parking brake before driving off after a standstill.
Do Not Ignore Check Engine Light
Check engine light is an amazing and essential tool provided to you by the car manufacturers. When it is on, this does not mean that you can ignore it and keep driving as usual. You have to take your car for a routine maintenance checkup to find out what can be the root cause of the problem. Ignoring this light can cause heavy damage to your car, which can be expensive to repair. Your car tells you about things like overheating of the engine, faulty ABS, and faulty airbag system through different lights in the instruments cluster in front of the driver.
Periodic Maintenance
Make sure you are undertaking periodic maintenance of your car. This is important since you can single out minor faults and get them repaired before they become worse and cause bigger damage to your car. This also saves you from incurring huge financial losses later on. Moreover, periodic maintenance improves the life of parts and keeps them at their optimal condition. Periodic maintenance does not usually cost much, and you will feel the difference in driving and handling of the car if you make this a habit. Change engine oil, oil filter, and air filter after their recommended time periods have passed.
Avoid Overloading Your Car
Overloading your vehicle is also detrimental to its health and reduces the overall lifespan of parts. Parts that get affected the most include tires, suspension, engine, and steering. Fuel economy worsens, and handling and stopping the car can be a problem for the driver. You can avoid overloading by only seating the recommended number of people. Also, unnecessary items from your car that you do not need on a daily basis. Furthermore, avoid overloading your car's clutch, e.g., when you keep pushing the clutch in heavy traffic. This results in the wear and tear of connected parts of the clutch system.
Stay tuned for more informative content like this one and drop your thoughts in the comments section below.
