you need to go "Wheel Alignment Center" to install TPMS because these two machines are required to install this product:
- Machine that separates tire from the Rim.
- Wheel Balancing machine.
Yes, ordinary mechanic can install it. The product also comes with an installation manual; however its too simple that pictorial view on website conveys the complete message. Side by side, we will guide you till the time you finish with installation of your TPMS. The installation should not cost more than Rs. 300-400 including wheel balancing. There is a small job of electrician just to connect master's wire to 12V supply so it should turn on when ignition key goes to "ON".
There is one year repair warranity. If not repairable, it will be replaced with new one.
There is no chance of sensor damaging even if tire get punctured and rim touches the road, you may be wishing to ask if it goes out of order. Yes, it can be replaced individually; its separate cost is Rs. 1500. If it goes out of order within one year, it will come under our warranity.
Other to warranity issues, you will find our company cooperative in after service.
