Originally published at: https://www.pakwheels.com/blog/dangers-inflating-tires/
Taking care of tires should be as important as taking care of other parts of the car. In our opinion, one should take more care tires due to their rough exposure compared to other components of a vehicle. In this article, we will be telling you guys about the dangers when a car's tyres over-inflate.
Before venturing into the cons of over-inflating the car tires, always remember to inflate the car tires as recommended by the manufacturer, as this will not only keep the tires of the vehicle safe but you as well from any awkwardness.
Blowout: The most lethal problem of the over-inflated tires is the blowout. It is highly possible that during your travel the car tires might blowout due to excess air; as over-inflation leads the tires to overheat; causing a blowout which further leads to a fatal accident, hence causing grave injury or even death.
Handling and driving comfort: Due to tires being over-inflated, the overall ride experience will become bizarre as you will feel every bump in the road. Moreover, the tires will become stiffer than usual; it will affect the traction of the tires much. Additionally, the handling and performance of the car will also get poor.
Uneven wear: Over-inflation makes the contact patch of the tires shrink, only the center of the tires is exposed to the road, which accelerates the wear of tires from their center compared to their edges thus causing uneven wear.
Untimely replacement of tires: Due to uneven wear and tear of tires one might need to replace the tires before their recommended change time. So, if you want to save both your money and tires, inflate them correctly as the recommendation provided to you by the manufacturer.
Get yourself a quality tire pressure monitor and air compressor on PakWheels store. That’s it, until next time, happy motoring!
4 IMPORTANT THINGS YOU NEED TO KNOW ABOUT TYRE PRESSURE
