Need to replace tires on a 2002 vti. Current tires on them are Bridgestone Ecopia EP150 205/65R15 which i have always hated from the beginning. Since i have to change tires i am also looking at changing the oem rims as well to a 16" or 17" versions.
Would you guys advise on whether its a good idea to switch the rim size considering the ride height is standard and i do not want to loose ride comfort and traction by a big margin. Main goal for switching is of course making it visually better.
Which tires will you suggest for both case scenarios and where can i get original product from within Pakistan. I am from Peshawar by the way.
FYI. Car is not stock engine, have swapped to 1.7 & produces a bit more power. Also current rims have small weights added on to them for correct calibration.
