AOA....Maray Pass Toyota 1NZ-EF engion ga. es may 1 ajeeb sa masla sure hogaya ha, har 6 Din band ya repeat hota ha. self gumata ha our ghari start nahi hoti. pir jub electrician ko ko k pass jata hou wo jub current dakta ha to har gaja pay ata ha. patrol b sahi ata ha lakin ghari start nahi hotai. pir khud b khud start ho jati ha, ab mujay koi bata saktay ha k es k sat kaya karo ?
6 din gadhi use hoti hai ya khari rehti hai?
rozana use hoti ha kareeb 6 to 7 Km
jis din start nai hoti, us din kya kartay ho start karnay k liye?
electrician ajata ha ya pir workshop lay jata hou waha pay wo logo plug ka current daktay han. oxygen sensor daklatay han. injuctor ka current daktay han. har jaga current daktay han sub teak hota ha pir ECU k wire nkaltay han uder current daktay han pir laga datay han pir try kartay han to khyd he start hojati ha. baki may pir andar bad jata self maray to mujay koi patay nahi chalta lakin electrician b conrf nahi tay k masla kidar ha
Mujag lagta ha es k ECU may problem ha lagta ha
Dekaa wrko ka na..
workshop kaisay lay jatay ho jab start he nai hoti?
dousri ghari k pechay band k
aur workshop may kaisay start hoti hai, electrician seechal oki che start she
workshop lay jata hou waha pay wo logo plug ka current daktay han. oxygen sensor daklatay han. injuctor ka current daktay han. har jaga current daktay han sub teak hota ha pir ECU k wire nkaltay han uder current daktay han pir laga datay han pir try kartay han to khyd he start hojati ha.baki may pir andar bad jata self maray to mujay koi patay nahi chalta lakin electrician b conrf nahi tay k masla kidar ha
@dayrider r u there ?
ecu ki wire utar k us ko saaf karo, and next time ho to stand with the electrician and see how he starts it
this time when it happens.
Switch car ON & OFF with 15 sec interval for 5 minutes means .. 20 times on & off with out cranking the engine. Then try to start.
I suspect clogged fuel filter & pump is failing to pressurise the injector rail
Dear i solved the problem.. the temp sensor is out of order , which give high Signal to ECU therefore the ECU stop the engine to start , the ECU feel like the the Car Temp is very High,
