Salam PWs...
I previosly asked a hell lot of questions about the motor 5efe.
I was away from the project for a long time due to uni issues...
Now I have packed up the motor.
With oem parts.
Now I need to knw timing marks on the cams. On the gears I thnk they are dmc cam gear.. (the gear with rachet and drives other cam..)
2- the wiring wala connected the ecu as a time bomb. I just check the whole wiring. The nsw (coming from the self motor solenoid+ was connected to SEL. As it was supposed to be connected to NSW
. Rectified.. but around 3 to 4 cranks were done before this rectification.
Now the main thing..
1. Need the cam gear timings for both rachet and timing belt
2. Does this problem effected the ecu?
Acc to me it didnt cuz coil pack working ok. And injectors too..
Sent from my SCH-I605 using PW Forums mobile app
