Bro, baqi cheezain be check karwayein.
Aapki car taqreeban 9,500 kms chall chuki hai (jub sey aap k paas aye hai), and aapney ub aa k ye 02 ka'am karwayeye hain. Ye b nai pata k aap k paas aanay sey pehlay iski last time full periodic / preventive maintenance kab hui thi, Yahan aa k hui b hai k nai?
Aap regular preventive / periodic maintenance must smajhein; at 10,000 kms (max.) or as and when required.
And avoid dealerships! Since aapki car warranty mein b nai hai, then why waste extra money on dealerships?
Market k mechanics ko innki nisabt cheezoon ka zyada behtar pata hota hai, and wo charge b nominal sa kartay hain. Most of the garages change engine oil, along with filter, free of cost.
Generally, hybrid vehicles k liay 0w-20 or 0w-30 oils recommend kiay jatay hain.
5w-30 are excellent for non-hybrid vehicles, but I am not sure regarding their usage in hybrid vehicles.
For any oil grade / viscosity, oil must be 100% genuine / original, API rating of SN and Fully Synthetic!
Any well renowned brand can serve the purpose well (Mobil 1, Liqui Moly, Caltex Chevron, etc.), but, avoid ZIC!
Yes, in hybrid vehicles, rear venting system is also there (to keep the batteries cool and at nominal temp.)
Agar unn mein blockage aa rai ho, then, I think, instrument cluster mein battery ki koi check light ON ho jati hai (that batteries temperature is rising), but, I am not sure that whether it affects milage or not?
Bro, aapnay engine oil and oil filter to change karwa lia hai.
Ye cheezain b check karwa lein (and if required, then their replacement, and the highlighted text should be replaced ASAP):
Air Filter, Cabin Filter, Spark Plugs, Throttle Body Cleaning / Service, Brake Service, ecu resetting.
Do check, if Catalytic Converter is choked or not? If its choked, get it serviced too.
Did you check the transmission fluid? Its level, color, viscosity, etc.
If its level is low and color / viscosity is deteriorated, then have transmission serviced too (Transmission fluid replacement along with Filter).
Check for wheel balancing / alignment too. Do rotate tires, you vehicle is almost at 10,000 kms.
I hope, it all helps. Thank you.
Btw, What's the Odometer reading of your vehicle?
