You say its after alignment. Is this a accidental vehicle?
I would jack up the car and check both wheel carefully, there are wheel sensor cables pull on each cable to check if its properly locked by gently pulling them. Also check for and damage to the wire/ broken.
After doing so try your car. If still this error is there try resetting by removing -ive battery terminal for 1 minute.
Update after doing these suggestion
